lt1 fuel rail covers
  • lt1 fuel rail covers
    any opinions on this mod, and does anyone have a pic with c4 vette covers on your f body
    thanks.....
    hmm...post a pic if you find one im curious how different it looks
      will do, i have found pics but they are not good enough to tell, very low res
        If I remember correctly, Will has them on his car. They looked pretty good, IMHO.
          Thanks for the props Bri! I made them myself by modifying C4 'vette FRCs.
            thanks will i had seen that pic before i just did not remember where, looks like you put bondo over the corvette lettering and sanded smooth. is the install hard do you have to move ne thing. do you or ne one know where you can find them cheap, all i can find is new frc, which i could do with just used ones.
            Thanks.....
              I don't like them, That's why i put LT1 stickers on mine instead.
                not a fan personally.
                Engine bay plastic is for silence and hiding all those "scary wires!" Obviously im not concerned about either
                  Thanks.....
                  I moved the wire bundle that runs along the top of the intake. I also had to cut the corvette covers significantly to clear vacuum and fuel lines.
