Wire Harness work
  • Wire Harness work
    Will any year trans am, camaro or corvette wire harness and pcm work with any year ls1??
    LS6 cam, LS6 valve springs, built tranny w/ 3k vigilante converter, 160 t-stat, SLP exhaust and headers, HAL suspension and go-fast juice
    No, you have small changes here and there.
    LT-1's changed 3 times from 93-97.
    I'm sure LS cars had changes in them from cams, transmission and what not.
      sorry i have 97 vette motor and i am wondering if a 98 trans am or camaro will work. the 97 was the first to have the ls1 in it so i was thinking that a 98 would work.
        I'm not sure about that??
        It will matter if the computer is for an M-6 or an Auto.
        There might be a few little things but I couldn't be sure about that.
          97-98 pcm and harness's are differnet.
            OK let me redo my question...what harness or pcm will work with an ls1 from 97? it was on a corvette but do i have to get a 97 harness or can i substitute a different harness in? looking to see what harness will work
              the 98's are differant than 99+. a 97 and 98 may work together
              you will have to change the fuel rail on that engine to put it in a F-body unless you use v6 fuel return lines
