fuel pump relay HELP!!!! 4th gen???
  • fuel pump relay HELP!!!! 4th gen???
    i have a 94 firebird lt1 was a 3.4 v6 looking for the fuel pump relay, does this exist on a 4th gen and where.
    my fuel pump dosnt always cycle when key is turned over further checking finding that there is no power at the pump. sometimes i need to screw with the ignition on and off till it fires the pump then it will fire up.
    or what else would cause this.
    not sure what would cause this, but im sure a LT or LS mod would fix it..
    on a serious note. im not 100 percent sure about the OBI V6 cars but the fuel pump relay should be under the hood in a fuse block on the left side?
    -Im Ron Burgundy?
      He swapped in the LT1....
      http://www.tcevolution.com
        i finally found in the book its located driver side behined the kick pannel, im thinking of going to racetronices this winter, im just tired of messin with this prob. odd that the interior needs to be puuled apart to get at it.
          Not sure where the stocker is, but the Racetronix kit is an easy install. The worst part is popping the old pins out of the stock harness to reuse in the new connectors.
          1997 Trans Am
          www.fquick.com/transampimp
            yea i would recommend the racetronix kit it was very easy to install
              wow im a tool. who needs to learn to read apparently..
              -Im Ron Burgundy?
                OMG. i tear the car apart and i see no relay just an empty plug and a quick connect with a wire running across the car to the engine compartment, havnt tracked it down yet but i do have a new relay on the way, i ran a jumper wire were the relay would be hit the key pump runs dont shut down but the car fired up every time i hit the key with out the throttle. im amazed my car didnt turn out like 1fstss or anothere buddie's, ive owned the car since 99 and never new this.
