As some may recall I am currently in the process of giving my newly acquired 94 Firebird with the powerful 3.4L a tune up.
The parts store lists an upstream oxygen sensor and a down stream sensor.
I am assuming the down stream is the one after the catalytic converter.
I picked them both up and then when I got under the car I found that there appear to be 2 oxygen sensors right near the engine on the exhaust pipes, one on each side of the engine. I also discovered that someone appears to have removed the CAT. and replaced with a straight pipe. I also noticed there is no downstream oxygen sensor.
Who ever did it did a good job because I cannot find a single cut wire, or cut tube or anything.
I also did not have any engine codes or anything when I drove the car, so I began to wonder the following.
1) Did all 94 Firebirds have Catalytic converters on them?
2) Is there a downstream oxygen sensor?
3) Shouldn’t there be a check engine light or something if there was supposed to be a downstream sensor and it was removed?
4) If it was supposed to be there and is removed, what would this, or should this cause any problems?
Thanks,
Thanks,
