Anyone know if you can get the pivot arm for the headlight assembly seperate? My passenger sight arm is pretty worn out and doesn't want to go down all the way.
98-02 Headlight Assembly
If its the metal arm why dont you spray it with some sort of break away or somethign similiar, mine was real tight and squeaked when I put the lights up, sprayed it and now its great. Hopefully that is your problem because the whole unit is very expensive.-Derek-
hey brian, I honestly don't want to get the whole assembly if i don't have to, I just need the pivot arm.Originally posted by bri2203 View PostAre you looking for a new part?
I will have a spare passenger headlight this weekend. I don't know if your interested in the whole item or just the adjustments/braces behind it.
