I just recently saved my ass off for a year to come up with the money to put a new trans in my car and finally got it in Saturday... well, I just went out to move my car and when I did, I started it up and after idling for a couple of minutes, it developed a serious rod knock. I feel sick to my stomach... There is NO way I can afford to even buy a used shortblock right now. I am simply broke. I don't know what to do. I'm not trying to get sympathy here... I just need to vent. This seriously sucks.
I just had the worst thing happen :(
sounds like my luck, anything that can go wrong will and you never have enough money to keep it running all the time. Sorry to hear about it. I'm guessing your positive its rod knock and not just piston slap or valvetrain noise?Doing less with more
Yeah, don't throw in the towel until it's confirmed.Originally posted by DETROITMUSCLE View Postsounds like my luck, anything that can go wrong will and you never have enough money to keep it running all the time. Sorry to hear about it. I'm guessing your positive its rod knock and not just piston slap or valvetrain noise?
Still...it sucks...
Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
To every action is an equal and opposite reaction. That means every good thing you do, something is bound to go wrong.
It also means if you're a dick to everyone, you're bound to reap tons of positive benefits.
Sucks none the less, though, man.- Brian Meissen
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
That sucks...I saw a LS1 block on craigslist for $600...dont know if thats a good deal or not2011 Ford Raptor SuperCrew
It *may* be a broken rocker arm/pushrod/lifter on an exhaust valve. I'm pulling the oil filter when I get home this afternoon to see if it has metal shavings from a bearing failure. If not, I'll pull the valve covers and see what's up.
Dude, That sucks.
Good news! I pulled my driver's side valve cover and found a broken valve spring. So all I need to do is get a new set of springs and I'm golden! Thank god it wasn't anything major.
