Jeff, i bet you can pick up a 383 ls1 shortblock pretty reasonable now with all the newer stuff out
Bad noise (Video)
Grammar Nazi
- January 10th, 2006
- 6647
- Jonny
- under par
- Huron Speed
Thats what I told him. Its deff not an exhaust leak tho. It sounds like a pushrod was just a little bent before and now its really bent and its banging around in there.Originally posted by 99TransAmWS6 View PostId pull the pushrods and see if any are bent. It sounds like that could be a possible culprit. Also when you did your headers..what gaskets did you use? have checked for exhaust leaks off the headers?
I hope thats all it is, Mike what are you doing this evening? Wanna find out what it is?Doing less with more
im gonna stick with saying its a pushrod.1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
2015 Silverado 2500HD 6.6 Diesel
2010 Corvette Z06
"The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
it does not have a mis at all and I get no lights on or any effect on driving itself.Doing less with more
I found the problem....
.....and couldn't be happier that its not a lifter, now its time to get a replacement set and change the oil because I'm sure it has metal in it now. Also most of the rockers were loose, as in side to side movement so they will all be removed and retorqued. Anyone got a set of stock rockers for cheap.Doing less with more
Dr LT1
- March 8th, 2007
- 8278
- Kyle L
- 1993 Pontiac TransAm V8
- Hudsonville, Michigan
- Machinest/CNC Programer
Glad you found it
Does anyone have a stock rocker they'd like to get rid of? I need one for a track rental next week.Last edited by DETROITMUSCLE; August 6th, 2008, 06:24 PM.Doing less with more
