Engine build Lt1
  • Engine build Lt1
    First things first...looks like the Lt1 has a spun bearing.... (still looking into it)
    poor thing. i am bummed seeing its only a summer car and i do not have time or money for it this year.
    So plans are a 396 stroker.
    Should i try to find a 4 bolt main LT4 block?
    also can i get any deals on this rotating assemblies
    http://www.eaglerod.com/products/Che...ssemblies.html
    ------ 12113 is the kit im looking at.
    looks like its around 1500 or so for the kit
    Thanks!
    just a bolt-on Lt1
    finding a lt4 block is prolly gonna be hard/expensive
    like i said 1500 is cheap that was like the cost of my pistons and crank
    The LS1 or Go Home Crew
    ASE master certified
      i found a seller on ebay for 1600 shipped "balanced" im going to see. I woudlnt mind paying like 700ish for a new block... but im not sure if i can find one. though
      just a bolt-on Lt1
        Well, sucks to hear that, man!
        Good luck with the build, and keep us updated on the progress.
        And get lots of pics!!!
          if it is internal it wont be done till next spring..
          just a bolt-on Lt1
            Check out that Golen engine service online. I believe they have Lloyd elliot porting the heads now. They could have you a rebuild much faster. Not sure if they are any good, but the site looks like they know what they are doing.
            1997 Trans Am
            www.fquick.com/transampimp
              i wanna build it myself so i can buy pieces here and there. i dont have the money with only making like $200 a week and classes costing $3,000.00 every 10 weeks. still trying to enjoy the summer too
              just a bolt-on Lt1
                iv having my block machined for 4 bolt caps
                just a bolt-on Lt1
                  How much do you think your block work will cost to clear that crank shaft? I was looking at the cnc-motorsports.com 396ci kit. those are nice also. But befor I spend money on a stroker kit i would send the block off and make sure its able to be stroked.
                  If it was me. I would just up grade to H-beam rods and Forged pistons. The stock crank is good for like 500rwhp on a bad day. So use a stocker. then with the left over money by some AFR 185cc or 195cc heads and air gap intake.
                  Also a LE3 with spary would be sweat!
                  So what is your power goals?
                  1993 Camaro
                  th-400
                  3.4 to lt1 swap
                  stand alone wire harness
                  coming soon ( just ask)
                  home made S400 frount mount turbo on the way
                  397ci 9:1
                  Goal 750rwhp+
                    its gonna be like 700 for 4 bolt conversion, clearance, and hone.
                    but i wanna do around a 230 244 .510 .530ish cam
                    and make 400+ out of an auto.
                    with 250-300 of spray
                    just a bolt-on Lt1
                      We have the 12113 kits for $1499.99, but they are not balanced. I would recommend getting it that way and having your machinist balanced the kit.
                        any deals also i was told the same..not get it balanced and have someone balance it all together
                        just a bolt-on Lt1
                          Thats some nice pricing for the labor $700 what is the name of the shop that will do it that cheap? also what is the cost with the 4 bolt main caps? Does that include sonic checkingthe block?
                          Also I see you plan on making 400 RWHP with a shot of spray. thats a nice goal. I had a buddy with a mild 396ci lt1 making 380rwhp . so i am sure the soary would help.
                          One other thing i notice is that in your sig you have " blown 396 on the way". what CR do you plan on runing? Keep that in mind while you are doing your short block.
                          1993 Camaro
                          th-400
                          3.4 to lt1 swap
                          397ci 9:1
                          Goal 750rwhp+
                            i know a guy that is doing work pretty cheap. but im not going F/I "Blown" is meaning the engine is bad now.. sorry for confusion.
                            just a bolt-on Lt1
                              just to clear up any misinformation, you do not need an LT4 block to get a 4 bolt main. ALL corvette LT1s were 4 bolts. Im not never sure if the LT4 had a different block than the vette LT1.
