95 Z28, what type of positraction was used?
  • 95 Z28, what type of positraction was used?
    How does the posi unit look on a 95 Z28?
    Is the axels attached with c-clips?
    Is it the same type of limited slip positraction as my 72 have?
    Magnus
    "If you're under control, you're not going fast enough"
    1972 Rally Sport
    Frame off restoration during 4700 hours. All the work, including paint was done by me.
    Started September 2003 and was done in August 2007.
    350 cui, M21 4 speed, 10 bolt 3:73 posi.
    1982 Z28E
    1 of 1300
    LG4 305 cui, TH200, 10 bolt 3:23 posi.
    1996 Sport Coupé
    Daily driver
    231 cui, 4L60e.
    http://www.garaget.org/CamaroZ22
    they use auburn differentials, and that appears to be a different setup.
      I googled auburn differetials but I couldn't find a good answer about how the axels are attached in the differential. Have anyone here ever restored a 4 gen rear end and know how it looks inside?
      Thanks/Magnus
      1972 Rally Sport
      1982 Z28E
      1 of 1300
      1996 Sport Coupé
      Daily driver
      231 cui, 4L60e.
        they are c clips, the unit in the 4th gen will have/should have a reluctor ring for abs or traction control if ur car has it
        The LS1 or Go Home Crew
        ASE master certified
          Ok then I know what to expect when I take it appart.
          Thanks/Magnus
          1972 Rally Sport
          1982 Z28E
          1 of 1300
          1996 Sport Coupé
          Daily driver
          231 cui, 4L60e.
