unsure if they are even replaceable but both my doors could use them, ecspecially the passenger door.
where to find 4th gen door hinges
not just sagging but when opening or closing, at least the passenger door moves up the down when opening or closing, but yes sagging also. how much are they and where to find them, i guess is the next question. thankssigpic
i dont know about your car but my 98 has bolt on hinges, unless they are spot welded and bolted on, which thats some pretty thick metal, maybe i can find some. if not then ill try the pin. thanks for the helpOriginally posted by GETGONE View PostWhat's wrong with them? The hinges are welded to the body I believe. Are your doors sagging? If that's all it is, then all you need are new door pins. Pretty cheap to buy but a pain to install and really should be done with a special tool to make it easier.Last edited by Formula Z; June 19th, 2008, 07:38 PM.sigpic
