i think syn i right but i don't want to add any fuel to the fire. you are probaly buying from a place that gets it from dupont. but what does it matter what you call it anyway
A/C Inop?
thought it would be funny cause i knew a "im right" war would be startedOriginally posted by lozanoa11 View Posti think syn i right but i don't want to add any fuel to the fire. you are probaly buying from a place that gets it from dupont. but what does it matter what you call it anyway
The LS1 or Go Home Crew
ASE master certified
No, Thats not what I was intentionally doing, Thats just what is called at the shop I work at. But whatever call it what you want dosn't really matter to me.
Originally posted by mister_grendel View Postrelated question: anybody know how I can replace the A/C compressor on a 3.8L v6 with a pulley?
As a matter of fact, I'm working on that one myself. My compressor's connector and guts came right out the top of the compressor, sooooo, no more compressor. Anyway, I've got a grooved idler pulley that I'm going to try to swap with the smooth one that sits between the compressor and the alternator and find a belt small enough to keep the tension between the crank and the new pulley, then I'm removing the a/c compressor, lines, accumulator, etc. all together. This may wait till spring, but I figured I'd throw the idea I had. No thread-jacking intended.sigpic
