Headliner fix?
  • Headliner fix?
    What's the easiest way to fix a saggy headliner? Besides the put tacks in it, or through it out method.
    get a new one
    '96 Camaro RS - project
    '97 Silverado Z71 - DD
    '89 Suzuki GSXF 750
      Can't i reglue the material on with contact cement or something?
        dont waste your time, it wont work and it got messy.
        just find someone parting out there car, they should be cheap.
        '89 Suzuki GSXF 750
          Is the headliner sagging away from the foam, or is the whole headliner sagging from the roof? My headliner was sagging from the roof and I was able to just use velcro to push it up into place against the roof.
          If the material is separating from the foam, it's kind of expensive but there is a company that makes and sells the headliners with ABS plastic. If I'm picturing it the way it sounds, it'd be much more stronger and last longer.
