head/cam kit
  • head/cam kit
    well, ive been digging through old threads and talking about it with a few peeps in the chatbox and found A LOT of helpful information. but, im still left with a lot of questions. looking around, i know that im gonna need to do some other things to support this swap. i have a decent understanding of what the numbers mean, but have no clue as to what will work best for what application or what will be the best combination. pace has recommended a 205 cc kit, but i am unsure of what would all be included in that. so, basically, i need some guidance. well, actually, i need a lot of guidance. i look forward to all your responses.
    this is an open ended question. What are your goals? What will you tolerate for drivability(cam size) What are your current mods?
      this is gonna stay a street/track car so i dont need a ridiculously huge cam and i already have borla exhaust and kooks headers. thanks
        Are you just trying to add a little power for every day, are you trying to have a weekend warrior, are trying to create a 500 rwhp 346 cid like patrick G...
        2013 Cadillac ATS
          oops i took to long to type, haha
          2013 Cadillac ATS
            do a either texas speeds 228r cam with 5.3 heads and be totally streetable and good at the track without reving it to the moon or you can go with a torqure v2 n those heads
              how much you looking to spend? I recommend TFS 215's with a low 230's cam. Pick the heads you want/can afford then pick the cam
              Take a look at some of the combo's posted in the dyno section of Ls1tech
                i will look into all of these, thanks guys. oh, please keep the suggestions coming. also, i would like to create a monster that would be alright for some daily driving.
                  get the best heads you can afford then a very mild cam. Great heads/ small cam will be much more driveable than decent heads with a big cam and make the same power
                    Yep get ready to drop some dough but a good set of heads should be first and foremost in this case then have Patrick G custom spec out a cam for you would be my best suggestion.
                      dont forget to look at a new ported oil pump, timing chain, pushrods, valve springs. If your doing a head swap..dont forget new gaskets, and head bolts.
                      1999 Turbo Trans Am WS6**Under Construction** Rear Mount Retired
                      Haters Quote "That car wont go faster then 10.50's" My response? You Lose!!
                      2015 Silverado 2500HD 6.6 Diesel
                      2010 Corvette Z06
                      "The SS looks like it could kick your ass if it wanted to, the WS6 looks like it's coming over to do it!"
                        yeah, i have a little list going of what i pulled from other threads. along with all this stuff, im gonna do the ls6 intake along with the converter (havent decided which one yet), and i read in another thread that i should go with the ls2 timing chain and dual valve springs just to be on the safe side. thanks again guys!
                          you already have an ls6 intake if its a 2002
                            lol, then i guess i dont need that. good thing im still reading up on this theres gonna be a lot of work to do...
                              Pace (Justin) sugjested the AFR's
                              Best head on the market!!!
                              http://www.airflowresearch.com/ls1.php
                              AFR 205's:
                              http://www.airflowresearch.com/205_mongoose.php
                              AFR 255's:
                              http://www.airflowresearch.com/225_mongoose.php
                              They can also have the heads ready to go so all you have to do is bolt them on and can hlep you pick a good cam for your application.
                              Justin can help you with this stuff I'm sure.
                              http://www.ls1tech.com is a great place to get info too.
