What size wheels on 4th gen. what tires
  • What size wheels on 4th gen. what tires
    I am looking at buying a set of rims in the next couple weeks. Wondering what size I can go with. i am looking at 17x9.5 front and 18x10.5, I asume these will be ok. Also what would you suggest for tires. I dont realy race mostly for street use but i want them to grip a little. mainly looking to keep my costs down. i will prob by some zo6 replica wheels. Thanks all.
    I have a 95 formula.
    West Michigan Firebird Club
    www.wmfirebird.com
    275/40/17's on the front and 295 or 305/30/18's on the rear. 315's are a bit wide for a 10.5" rim. They're usually recommended on an 11" rim or wider.
    Wade
      Unless you have a LOT of power, 17x9.5 will be perfectly fine on all 4 corners. Heck, the GMPP LS7 Camaro is running the exact wheels I have (solid black 17x9.5 C5 Z06), and that thing has over 500 hp. Staying away from the 18x10.5 stagger will also keep the cost down since the bigger tire is more expensive than the 275/40x17 that would go on the 17x9.5. Hope this helped!
      www.BroughtonAutomotive.com
      www.fquick.com/Camaro_Driver_19
        But wider tires on the back just look more badass!!! I was going to go 17x11's in the rear with my ZR1's till I put the 18's on. They only came in 9.5" so no real wide tires in the back for me. I have been considering 295's when it comes time to replace them since they will fit on a 9.5" rim.
        Wade
