Ok this is a pretty simple problem... the shifter handle on my Pro 5.0 keeps coming loose. I have torqued the allen head bolts for all I am worth and pretty much stripped them from doing so, so many times and it still just keeps coming loose. Jon is having the same problem with his factory hurst shifter. With the pistol grip and my speed shifting... it just keeps happening. Anyone have any suggestions? Ive tried loctite, teflon, you name it... does anyone here have a simple remedy? about ready to yank the whole thing and run some serious bolts through it. Im not sure how much room i have to drill out, but thats just a matter of looking...
Shifter handle keeps coming loose
WTB List:Midwest Chasis DS Loop -
lol i guess this was a stupid question, im gonna go take it apart and i see what i can fabricate.-Joel
The way i see it, the designer of the Pro 5.0 failed on 4 levels with just the handle screws:
1) allen head screws - impossible to get leverage on
2) allen head is an oddball size, so they strip easy (but the rest of the allen screws on the shifter fit perfect)
3) the screws arent long enough to put a lock nut on the other side which would solve the problem
4) the screws are an oddball thread... not regular or fine, no theyre their own special type.... so none of the 3000 bolts my dad has laying around are any good.
Im thinking about taking the whole thing out and drilling it out.... i just really dont feel like messing with my console.-Joel
Pull it and redrill and retap I say then use your own bolts with lock washers and loctite
I bet they're metric.Originally posted by JoeliusZ28 View Post....4) the screws are an oddball thread... not regular or fine, no theyre their own special type.... so none of the 3000 bolts my dad has laying around are any good......Last edited by WMCC Gary; May 6th, 2008, 10:23 AM.Western Michigan Camaro Club ~ President
1987 Camaro IROC-Z Pearl White & Black w/ Red Pearl, 355 TPI, A4, 3:42, AirRide,"GOMARO"2017 Silverado Double Cab Z71 Pepperdust Metallic, 5.3, A6, 3:42, "SASYZ71"WMCC Website www.wmcamaro.org
are willing to work and give to those who would not." — Thomas Jefferson
yea i was going to fix my post last night, i figured out they were metric not even 10 minutes later, when i found some of my spare motorcycle bolts fit. Im checking for a longer variant at my dads work, if there isnt one there im going to go to the auto parts store or home depot and get one. That way i can put a lock nut on the end and it will be a closed book.
And james the threads arent fubared up... the original bolt's threads are fubared up in the middle, but its from the force of shifting. I havent been forcing the wrong bolts in there or anything. I compare to the original before i just go forcing things.
guess i must be a little rougher with mine, red loctite didnt work at all for me.Originally posted by 1BADAIR View PostI haven't had the problem since I started using red loctite on mineLast edited by JoeliusZ28; May 6th, 2008, 11:40 AM.-Joel
Ah, there's your problem then, cheap bolts. No way a bolt should lose it's threads before a tapped hole. See if you can snag some 10.9 class bolts when you go get some new ones.....if not, let me know what size and I can probably get you some.Originally posted by JoeliusZ28 View Post
sigpicTurbo Charged LS1/T56
