edit
95 LT1, i am using a fbody radiator but i think the water pump (which is off a bbody) is not the same as the fbody water pump.
Lower, drivers side of the radiator is a coolant hose opening, however from the diagrams i have seen this would go into the water pump. However there is no inlet on the water pump i have.
Will it be ok if I just block this off the radiator?
