A few questions...
  • A few questions...
    1. Any tips on removing the manifold to Y pipe bolts? I ALWAYS snap them off and i dont want to get new studs (yes i have tried PB blaster and so far hasnt done any good)
    2. Anyone have pictures of subframe connectors installed on there car? I dont know how i have never noticed before but there are two steel bars on each side running along beneath the door area
    3. Will 18"/19" OEM C6 rims fit without spacers on a 4th gen?
    thanks
    '96 Camaro RS - project
    '97 Silverado Z71 - DD
    '89 Suzuki GSXF 750
    thanks
    1. Sorry man i cant think of anything. I snapped a few on mine and i soaked my bolts for a good 3 days.
    2. Those are probably SFCs... but not the double-diamond type. If you want to see what a double diamond looks like installed, check out my winter project thread where i a painted my undercarriage. My SFCs used to be red so they should be easy to spot.
    3. I think so... but dont take my word for that.
      2. yep those are definitly there, i dont have any pics of under my car
      3. as you can see i have C6's rims on my car, they are replicas but i dont see why they would be any different
        Those studs will require heat. From underneath. I really don't know how you'll get heat to them on a 4th gen. Good luck.
          are those OEM specs? I believe OEM C6's are 10" or 10.5" wide
          car will be lowered too though, yours is lowered right?
          I will check out your thread
          Thats what i was afraid of, I dont think there is a way i can safely heat those up w/o burning other stuff
          '89 Suzuki GSXF 750
            OEM C6's will NOT fit. The spacing and stuff is different. Replicas are made with the right offset. I know someone who had real C6's put on their F body and it took some machining and other work to get them to fit properly.
            Wade
              You might have to remove a few things to safely heat them. I've never done it on a 4th gen... wheewwh, that's a tight area. It's a lot easier on my third gen, but still tight. On my 92 GMC K2500 I could wave a torch around with my eyes closed and probably not hurt anything
                crap
                hopefully someone outbids me!
                i searched ls1tech (of course after i bid on some rims ) and you need 1.25" spacers on the rear rims
                '89 Suzuki GSXF 750
                  crap
                  You can get those off ebay too.
                  98 Trans Am WS.6
                  Cam
                  Heads
                  Intake
                  Full exhaust
                  More mods to come
                    yep i saw some for 55 shipped
                    well i won the rims 8-O
                    http://cgi.ebay.com/ebaymotors/ws/eB...229815875&rd=1
                    '89 Suzuki GSXF 750
                      Strip those and paint them black...would look sweet on your car
                        im going to see if my friend can have them powdercoated
                        if not i do plan on painting them black
                        oh just removed the stock Ypipe, managed to break two bolts at the collectors .... i'm a pro at making more work for myself
                        '89 Suzuki GSXF 750
                          An easy way to heat those things up would have been to just start the car let it run for 20mins than shut it off and get at it. I mean its nothing like torching them but it would probably have helped.
                            that would have been a good idea
                            '89 Suzuki GSXF 750
                              LOL, sometimes it's so simple you just overlook it
