problems idling
  • problems idling
    well over the winter i put a lt4 hot cam kit into my 96 z28. ive driven it just a couple ouf times and everytime it has trouble idling. the tach will rest at about 1000 rpm then drop to 500 rpm sometimes correcting itself other times it just stalls out. it generally tends to stall at slow speed when i brake. i have no idea whats wrong anybody got any help ??
    its a 6 speed and no im not the one stalling it before any1 says anything
    did you get it tuned after you put the cam in?
    http://www.tcevolution.com
      no i did not sum1 told me to adjust the minimum idle
        Moved to 4th Gen Tech
          Im no expert by any means, but i have always thought if you do a cam, you should do a tune, to take full advantage of it.
            Sounds like a vaccum issue to me...
              tune
              The LS1 or Go Home Crew
              ASE master certified
                it needs a tune PEROID. no mail order bullshit either.
                  well time to start saving for a tune.
                    hey i'll talk to sean at cars, i got me and a buddy going in for a tune together he said 400, maybe if i bring you as well we can all get a tune for like 350 each
                    we wont be going for about 3 weeks
                      lol that would be great ill c if i can get some money together in that 3 weeks my bank account is pretty much tapped . lol a solid $13
                        damn thats impressive. now on a $400 tune, thats a dyno tune correct?
                          i am pretty sure its a dyno tune unless i was misinformed, it would be kinda cool to get a like group dyno tune together and get a nice deal
                          depending how long my damn new cam takes it may be 4 weeks
                            if you get the right guy you can get a quick tune for that hot cam to work but no way will it work without the tune. my car has the 93 motor computer package have to pull the entire comp. out and have it burned in and then run it agian. if its 94 And up just a simple hookup.
