you might be able to get away with just replacing the rod bearings. You have good oil pressure so your mains should be fine.
The culprit is usually cylinder number 8. If you arent so lucky, the crank and rod themselves could be damaged too. This is usually what most people have to replace, but if the car hasnt been run much since it happened, you might be OK.
ok
im was thinking about hanging on to a spare LT1 for a project or something someday
i will look into what it takes to change those bearings
And the oil pan won't come off because the K-Member is in the way and you can't get low enough to claer te oil pump.
You need to pull it to do it right but it sounds like that's what you are going to do any how.
how is anyone owned? why would you want to change rod bearings in the car when you have the tools to make life easier like Adam does? and both people that have gotten their oil pans out have LS1s. Thats besides the fact that this engine is NOT going back into the same car, therefore its coming out anyway. Why would he change bearings in the car, for the fun of it??
