Do 4th gen cars use a resistor to shunt voltage for slow speed blower operations? Can't find a part or any info anywhere.
Blower motor resistor, or nah?
Blower Motor Resistor Assembly Replacement
Removal Procedure- Remove the right IP insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gauges and Console.
- Position the carpet away from the HVAC module assembly.
- Remove the blower resistor assembly bolt (2).
- Disconnect the blower resistor assembly electrical connector.
- Remove the blower resistor assembly (1).
- Install the blower motor resistor assembly (1).
- Connect the blower motor resistor assembly electrical connector. [COLOR=blue !important] Notice: Refer to Fastener Notice in Cautions and Notices.
[/COLOR] - Install the blower motor resistor bolt (2).
Tighten
Tighten the bolt to 2 Y (18 lb in). - Reposition the carpet.
- Install the right instrument panel insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gauges, and Console.
zeeman likes this.
- 1 like
