anybody care to translate the maning of this odbII code
  • anybody care to translate the maning of this odbII code
    P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
    got it last night reset it and it did not come back just curious what it means. thank you Allen
    ___________________________________________
    1994 camaro z28 ca kit & exhaust upgrade
    1996 camaro z28 ca kit, BBK shorty headers, hypertech 160 thermostat and program, exhaust upgrade, lt4 knock module
    I can't remember if that's the one you get when the gas cap isn't tight(at least 3 clicks) or if it's a vaccum leak. Might be something else entirely though. My service manuals are for V6 and LS1 cars so I'm not sure if it would be the same on an LT1. I'd have to dig my manuals out and look.
    Wade
      Was your car running bad, poor idle or stalling? I have a service manual for the LT1's and it says a lot about that. If your car wasn't running rough it probably was just the loose gas cap.
      98 Trans Am WS.6
      Cam
      Heads
      Intake
      Full exhaust
      More mods to come
        no I had drove it about 30 miles parked came back out a few hours later started it and that code popped up, drove it home fine, put the code reader on it the next day checked the code and erased it, restarted it and it did not come back on. had a couple replies on another camaro board but nothing solid yet. thank you
          hopefully something here can help
          DTC P1441 Evaporative Emission (EVAP) System Flow During Non-Purge
          Circuit Description
          The EVAP vacuum switch is a normally closed switch connected to ground, mounted in the vacuum line between the EVAP canister and the EVAP solenoid. 12 volts is supplied to the switch through a pull-up resistor in the PCM. When the PCM commands the EVAP canister purge solenoid valve open (purge ON) and engine vacuum draws the evaporative emissions from the canister, the EVAP vacuum switch opens (signal voltage high) providing feedback to the PCM that the EVAP system is operating. When the PCM commands purge OFF, the EVAP vacuum switch closes (signal voltage low) confirming purging has ceased.
          Conditions for Setting the DTC
          • DTCs P0100, P0101, P0102, P0103, P0106, P0323, P0325, P0327, P0332, P0335, P0336, P0372, P0400, P0403, P0410, P0412, P0420, P0430,P0441, P0443, P0500, P0502, P0503, P0506, P0507, P0530, P0531, P0719, P0758, P1415, P1642, P1652 not set.
          • ECT less than 115°C (239°F)
          • IAT greater than 3°C (37°F)
          • Engine speed between 500 and 3000 RPM
          • TP Angle less than 50%
          • MAP less than 70 kPa
          • BARO greater than 77 kPa
          • Purge not enabled
          • The PCM detects high signal voltage on the EVAP vacuum switch signal circuit when the PCM is not commanding purge ON.
          • Fault present for 5 seconds
          Action Taken When the DTC Sets
          • The PCM will illuminate the Malfunction Indicator Lamp (MIL) on the second consecutive drive trip that the diagnostic runs and fails.
          • The PCM will record operating conditions at the time the diagnostic fails. The first time the diagnostic fails, this information will be stored in Failure Records. If the diagnostic reports a failure on the second consecutive drive trip, the operating conditions at the time of failure will be written to Freeze Frame and the Failure record will be updated.
          Conditions for Clearing the MIL/DTC
          • The PCM will turn the MIL OFF after three consecutive drive trips that the diagnostic runs and does not fail.
          • A last test failed (Current DTC) will clear when the diagnostic runs and does not fail.
          • A History DTC will clear after forty consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
          • PCM battery voltage is interrupted.
          • Using a Scan tool.
          Diagnostic Aids
          Before replacing any components, visually/physically check for the following:
          • Mis-routed harness.
          • Rubbed through wire insulation.
          • Broken wire inside the insulation.
          • Kinked or damaged vacuum hoses.
          • Physically damaged system components.
          • Inspect components and vacuum lines for traces of carbon or other contaminants. The presence of foreign material may be causing a restriction in the system or preventing the solenoid valve from closing properly. Either condition may cause a DTC to set.
          For intermittents, refer to Symptoms .
          Test Description
          Number(s) below refer to step numbers on the diagnostic table.
          1. Since the vacuum switch only requires a vacuum of only a few inches of water to operate (a very small unit of vacuum), a properly operating switch will transition even with the canister end of the hose disconnected and un-plugged.
          Step
          Action
          Value(s)
          Yes
          No
          1
          Was the Powertrain On-Board Diagnostic (OBD) System Check performed?
          Go to Step 2
          Go to Powertrain On Board Diagnostic (OBD) System Check
          2
          Important: This DTC will set if the vacuum lines at the EVAP purge solenoid are reversed, Refer to under hood emission label for proper routing.
          1. Turn the ignition ON, engine OFF.
          2. Using the scan tool, check the EVAP vacuum switch status.
          Does the scan tool indicate, EVAP vacuum switch No Purge.
          Go to Step 3
          Go to Step 6
          3
          1. Start the engine.
          Does the EVAP vacuum switch status change to Purge when the engine is started?
          Go to Step 19
          Go to Step 4
          4
          1. Start the engine. Increase the Idle speed to 1500 RPM.
          2. Using the scan tool, command the EVAP canister purge solenoid valve ON and OFF while observing the EVAP vacuum switch status.
          Important: When the EVAP solenoid is commanded ON then OFF, the scan tool display should change from Purge to No Purge almost immediately.
          Does the scan tool indicate No Purge within the time period indicated?
          5 seconds
          Go to Diagnostic Aids
          Go to Step 5
          5
          1. Turn the engine OFF. <LI type=1>Disconnect the purge hose from the canister (the vacuum line from the EVAP vacuum switch). Refer to Evaporative Emission Canister Replacement . <LI type=1>Start the engine. Increase the Idle speed to 1500 RPM.
          5 seconds
          Go to Step 11
          Go to Step 12
          6
          1. Disconnect the EVAP vacuum switch harness connector.
          2. With a test light (J 34142-B) connected to B+, probe the ground circuit at the EVAP vacuum switch harness connector.
          Does the test light illuminate?
          Go to Step 7
          Go to Step 13
          7
          Connect a fused jumper wire between the EVAP vacuum switch harness connector terminals.
          Does the scan tool indicate EVAP vacuum switch No Purge?
          Go to Step 14
          Go to Step 8
          8
          Using a DVM (J 39200) connected to ground, measure voltage at the signal circuit of the EVAP vacuum switch harness connector.
          Does the DVM indicate voltage near the specified value?
          B+
          Go to Step 18
          Go to Step 9
          9
          1. Turn the ignition OFF. <LI type=1>Disconnect the PCM connector C2.
          2. Using a DVM J 39200, check for continuity between the EVAP vacuum switch signal circuit and ground.
          Does the DVM indicate infinite resistance?
          Go to Step 10
          Go to Step 16
          10
          Using DVM J 39200, check continuity of the EVAP vacuum switch signal circuit from the vacuum switch harness connector to the PCM connector.
          Does the DVM indicate resistance is less than the specified value?
          5 ohms
          Go to Step 20
          Go to Step 17
          11
          Replace the EVAP canister, refer to Evaporative Emission Canister Replacement . The EVAP system must be inspected and/or cleaned before replacing any component. Refer to Evaporative Emission System Cleaning .
          Is the action complete?
          Go to Step 21
          12
          Repair restricted or kinked hose between canister and EVAP vacuum switch, refer to Evaporative Emission System Cleaning for cleaning procedure.
          Go to Step 21
          13
          Repair the open ground circuit.
          Go to Step 21
          14
          Check connections at the EVAP vacuum switch.
          Was a problem found and corrected?
          Go to Step 21
          Go to Step 15
          15
          Important: Contamination can cause the switch to fail. Refer to Evaporative Emission System Cleaning for inspection/cleaning procedures.
          Replace EVAP vacuum switch, refer to Evaporative Emission Purge Vacuum Switch Replacement .
          Go to Step 21
          16
          Repair the shorted signal circuit to ground.
          Go to Step 21
          17
          Repair the open signal circuit.
          Go to Step 21
          18
          Check the connections at the PCM.
          Go to Step 21
          Go to Step 20
          19
          Important: Contamination can cause the solenoid to fail open. Refer to Evaporative Emission System Cleaning for inspection/cleaning procedures.
          Replace the EVAP canister purge solenoid valve, refer to Evaporative Emission Canister Purge Solenoid Valve Replacement .
          Go to Step 21
          20
          Important:: Replacement PCM must be programmed. Refer to Powertrain Control Module Replacement/Programming .
          Replace the PCM.
          Go to Step 21
          21
          1. Using the scan tool, select DTC, Clear Info. <LI type=1>Start the engine and idle at normal operating temperature. <LI type=1>Select DTC, Specific, then enter the DTC number which was set.
          2. Operate the vehicle within the conditions for setting this DTC as specified in the supporting text, if applicable.
          Does the scan tool indicate that this test ran and passed?
          Go to Step 22
          Go to Step 2
          22
          Using the scan tool, select Capture Info, Review Info.
          Are any DTCs displayed that have not been diagnosed?
          Go to the applicable DTC table
          System OK
            Todd is the bomb!
              mine was the solonoid, and 2 hoses on my car( looking at engine on left of the intake manifold, small black thing with 2 small hoses running to it)..thankgod for cost on gm parts
              just a bolt-on Lt1
                I replaced the purge solenoid yesterday so we shall see, 39.00 at the dealer, same part at autozone was 19.00, I bought the dealer part funny thing though I told the dealer how much it was at murrays and he said probably cheap chinese part as he handed me my new gm part from mexico as it stated on the box, godd thing it wasnt imported huh
                  yeah i got mine at cost which was 30.00 for all hoses and the solonoid i do belive. good luck my emissions are still screwy. LT Race Headers should help me there
                  just a bolt-on Lt1
                    well I replaced number 7 from this diagram got a code still today, did you replace 7 or 11, thank you Allen
