Ok, so I go to drive my car a little bit today, and it was running fine. I get it about a mile away from home, and it starts missing, backfiring a little and it had absolutely no power at all. I shut it off, restart it and it runs fine again for another mile, then starts doing it again. Mind you, a week ago it ran perfect for 50 miles. I did pull a spark plug and it looked kinda bad, so Im gonna replace them anyway, but does anyone know what the heck is wrong?
Wierd running problem
http://www.youtube.com/watch?v=b8-pCbQnSC4
"Wow Pete, I have to say your balls are so tender."
"Well theres no beating my balls, the are made from a secret Schweddy recepie." -
well do the spark plugs and see...also check the wires and if it keeps doin it it may be an opti issue2011 Ford Raptor SuperCrew
If its the opti im gonna be pissed, cause its only about 3 months old and less than 2500 miles...http://www.youtube.com/watch?v=b8-pCbQnSC4
yea i would do the plugs and wires and hopefully that solves the problem2011 Ford Raptor SuperCrew
How do you suggest is the easiest way to do the plugs on the lt1?http://www.youtube.com/watch?v=b8-pCbQnSC4
No because the wires are MSD 8.5 and they were on the car for about two weeks before I did the opti, so I didnt change themhttp://www.youtube.com/watch?v=b8-pCbQnSC4
Nope, no code, and the cat has been taken out and pipe is welded in its place since ive had it. The thing that I dont understand is why it just decided to do it today, and it fixes it self for a mile once its shut off and restartedhttp://www.youtube.com/watch?v=b8-pCbQnSC4
One at a time and take your time...well you can hurry but it will end up taking sometime cause they are a *****Originally posted by goblue9976 View PostHow do you suggest is the easiest way to do the plugs on the lt1?2011 Ford Raptor SuperCrew
I'll go with a clogged fuel filter...Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
I was thinking EGR valve, personally.- Brian Meissen
Could be, very well could be...Originally posted by meissen View PostI was thinking EGR valve, personally.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Cant be the fuel filter cause that too is less than 5k miles old. I pulled 2 plugs already and one of them didnt have any white spot on the fireing point, so Im assuming that the plugs were bad. Now, the EGR, how could I check out if its bad or nothttp://www.youtube.com/watch?v=b8-pCbQnSC4
