a couple questions...OD vs D and seafoam
  • a couple questions...OD vs D and seafoam
    Seafoam, it doesn't say exact instructions on the bottle but you just pour X amount into the oil-fill and run it? How long?
    I plan on changing the oil right after i run it. Also, i was searching and does this stuff harm your car sometimes?
    next question.
    OD vs D
    I leave my car in D and then switch into OD a little over 2K rpms
    mine 99 will shift into 4th (when OD) around 35 mph if i dont keep in 3rd (D)
    I heard along time ago from some mechanic that this is easier on the transmission in the long run or is that just a myth or something?
    '96 Camaro RS - project
    '97 Silverado Z71 - DD
    '89 Suzuki GSXF 750
    don't change the oil right away after seafoam. Run about 80-100 miles to allow it to work itself around and break up gunk. Then change the oil. It will be think with crap
    Leave it in OD and don't worry about it
    5th gen Camaro V6 Forums
    http://www.bowtiev6.com
      the only time i use D instead of OD is in high traffic situations where im continuously "making my move" and im sparing my trans several downshifts.
        good thing i asked about the seafoam,
        i prefer D regardless b/c its annoying when it shifts into 4th at low speeds...just curious if that guys statement was bs
        '89 Suzuki GSXF 750
          read the tutorial section for seafoam ..and so far from alot of reading ive done on seafoam it wont harm it at all yea some people have bad experiences and i dont exactly know why
          If your going to seafoam..mid as well go the extra mile and do it everywhere else
          def. a nice lil smoke show..well..my engine at least did
            I wasn't to crazy about using seafoam in my oil. I poured most of the can into the brake booster vacuum hose. The rest I dumped into the gas tank. It really does a great job breaking up carbon in the intake. She blew smoke for a good 10 minutes.
            1997 Trans Am
            www.fquick.com/transampimp
              i did mine this last summer also through the brake booster. smoked for about 5 minutes. couldnt really tell a difference, but it didnt seem to hurt. ill do it again this spring, might try the gas tank some.
                my car has 187K on it so i'm sure it could use something like this.
                wheres that write up? I couldn't find it
                so just pour in the brake booster hose?
                '89 Suzuki GSXF 750
                  click tutorial system @ the top..and just look for it there..its there
                    http://www.mifbody.com/vbulletin/tut...=view&tutid=11
                    there ya go
                      thanks man, awesome write up
                      just one question
                      is the "Deep Creep" basically carb cleaner?
                      '89 Suzuki GSXF 750
                        yea but I like it a lil better than just regular carb cleaners
                          good stuff - just follow the directions
                            yup if you follow every direction..expect good results..
                            when I seafoamed mine (probably for the very first time it was ever seafoamed)
                            had a very nice smoke show...just let it sit there for sometime idling watching smoke pour out..then took it on the highway and let it rip
                              I love seafoam.
                              works good for me.
                              I actually just added a full can to a 1/2 a tank in my explorer.
                              when I get a different car....thats the 1st theing that goes in the oil.
                              Then I drive for 50 or so miles and then change the oil.
                              In my trans am...I drive aroundf in "D"
                              until I go over 40mph (highway) then ill shift into "OD"
                              LOL....hell sometime if im cruzing.....i drive in 2nd gear.....I like to hear my motor and exhaust.
