Any OBDI guys running a wideband here?
  • Any OBDI guys running a wideband here?
    what sensor/parameter are you tapping the wideband output into for datalogging?
    Ive read AIR/EGR are possibities, but im still running those systems so is prefer to find something else.
    Can't you just tap into the rear O2?
      no rear O2 on OBDIs.
        doing some reading and it looks like the A/C pressure sensor is my answer, but thats all ive found so far... Seems i might be in for more pioneering than i had thought.
        it seems that a lot of people record AFRs vs RPMs with the controller itself and then later match it to the datalog manually...
        i think thats kinda ghetto im determined to log AFR through the pcm
          bump for monday crew
            I use EFIlive with my LC-1
