well as long as you didnt have the battery unplugged for too long it should hold the idel settings... i think it has to be out atleast 24-48 hours before it will reset back to factory and depending on what programmer you used sometimes they never go back to factory settings depending on what computer is in it... i had the same thing on my grand prix i did very little mods to it but enough to mess the stock program up... turn it on it would idel at like 2,500 rpm for a good 45 seconds before dropping down... then when it did come down to like 1,000 it would jump up and down for another 5 miutes atleast before it smoothed out... i couldnt figure it out... then just tossed the programmer on it and changed my idel setting back to where it was supose to be no problems after that... but if i pull my battery for too long i have to do it again
Need some HELP in Ann Arbor!!
My moms car did that after having a dead battery for about a day and a half, but after I cleared the trouble code it worked fine.Nick H.
Current MIFC Vice President
Adrian... I have the Thunder Racing 224/224 112 lsa cam 563/563 lift...it's a very nice streetable cam. my car came with it already in...and it makes a good chunk of power around 2500 rpm all the way to the top!.... but yeah your symptoms sound identical to mine...just worse?1998 Camaro SS Bullseye Turbo
http://www.mifbody.com/vbulletin/vbp...p?do=view&g=11
here's the link to my little "members garage" it's a little more indepth on what's all going on under my hood!
Matt, thanks for the link! Very nice...I need all suspension mods myself...haha. Spent all my money on making it go "faster". As far as the problem, I agree. I think we have the same problem, mine is just worse. I think I've narrowed it down to the throttleplate closing when coming off of the gas, and it choking down the engine. It also has to do with it not being completely warmed up. The worst of my problems is now the fact that I have to open up my throttleplate more which is causing a higher and higher idle rpm. I have it to the point now where it idles at 1K even. While driving now, it'll bog just a little for a few mins, then it will start the high idle cruising bit. I probably need to open up my throttleplate just a bit more to help eleviate anymore boggin issues, and then i'll have to get my IAC valve tuned to act properly and not cause the crusing idle bit.
I honestly don't see any reason for the "cruising" idle. It never did it before I installed anything, so I'm assuming that its not at its stock parameter. But I don't really know, I really wish I new someone with HPTuners or EFILive. That way we can really get in there and clean up this mess!
06camarodude, you have a PM!
Thanks!
Adrian
No I don't. . . I just checked, and I didn't recieve a PM. Just email me at saxman06@comcast.net That would be easiest for me.Nick H.
No prob, I got it now lol. I sent you a reply too. I'll call you tomorrow.Nick H.
Yeah... everynow and then my car will act up worse. but for the most part it just idles weird from the cam. as cams do that....But i've noticed in extreme temp changes (like if i pull my car into the shop at work to wash it on a 30 degree day. when i pull it into the warm shop. it idles like hell...and usually dies unless i keep revving it some)....or if my car is not warmed up it will act up. however my symptoms are not a cause for concern like yours...by the way...what size cam did you put in? and who dyno'd/tuned your car?
on a side note...yeah i just did all my suspension in the fall...i blew the stock 3.42's to hell lol...so when i ripped out my rear end, i decided to replace everything else while i was at it (part of my OCD lol) i also had my trans re-built by D&D out in wixom. and had a host of problems with SPEC and my clutch/flywheel. but now all is good...and my car runs like a raped date!!!!
Hope some of this might help you? i believe that your cam is bigger than mine (which it must because of your #'s you're putting down. im sure my car would be in the same boat as yours if i had a bigger cam)1998 Camaro SS Bullseye Turbo
whatever happens, post up what it ends up being.-Joel
My cam is pretty big, but I think i've started to narrow down the issue. First I believe that my throttleplate wasn't open enough, so when coming off of the gas, it would choke down my engine. Now I opened up the throttleplate some more, and eleviated my bogging issue...for the most part. It'll still do it sometimes, but I think I just need to open it up some more, or drill a hole based on the voltage that the TPS is putting out because if its above .62V it'll go into a different timing table and will give me automatic cruise control. Anyways, I need to get my RAF tables remapped, and play around with my idle spark tables and my cruising idle speeds ect... There is just a whole lot more to this then I understand at the moment and hope I can gain a better understanding of the situation! I also had my tuning done at Livernois. Too bad I just didn't buy the software myself...costs just as much...
Adrian
Ps here is what all I have done to my car...incase you missed it in a previous post.
Cam = 228/236 .612/.590 114+2 LSA XER
Volant CAI
SLP MAF 85mm
FAST 90 intake
FAST 90 Throttlebody
SVO 42# injectors
ARE Stage 3 heads (.327 cfm at .600 lift) 61cc chamber yielding ~11.1:1 compression, 2.055 int/ 1.60 exh (cam cleared with no flycutting)
PP Gold Dual spring kit good to .650 lift
Camp Cams 7.275" Pr
Morel Lifters
Edelbrock Stepped 1 3/4 to 1 7/8 headers w/ 3.5in slip-on merge collectors and ORY 3" back to a 80 series slowmaster with 4 in slashcut tips
Powerbond 25% UD pulley
well that's good you have figured it out....did that guy i think his name was something with a B...burnem or something like that tune your car....???? i've heard some horror stories about livernois...a friend of mine walked in while they were just bouncing a car off the rev limiter just laughin.....i would never go to livernois...too many cars have been blown up there from my understanding1998 Camaro SS Bullseye Turbo
Yeah, somebody really should start a thread about the best places to take a car to have it tuned. . . I'll do it. I have been post whoring for the last month or so anyway. It'll be up in a few seconds lol.Nick H.
yeah you have become the newest regular post whore lol...damn 1 month and you're up to 300 almost!1998 Camaro SS Bullseye Turbo
Yeah, I'm sick of being called a "Regular." I want to get up to at least "Fanatic" or "Teenager with nothing better to do than prove he has more free time than anyone else on MIFBody" lol I'm working on it. I'll have 300 by morning, I guarantee it. lolNick H.
