fuel pump
  • fuel pump
    Has anyone done a fuel pump and a 94 trans am? If so is there anyone that can tell me the easiest way to do it i thought about cutting a hole in the trunk to get to it but i dont want to cut into anything like the fuel lines or the tank itself. Just wondering if someone had a real easy way to do it other then taking the exhaust and panhard rods off to make clearance for the tank to come down. Thanks
    Man, I think you might be SOL on this one, if it were me I wouldn't want to cut a hole in my floor. You could, but I wouldn't.
      It takes about the same about of time to do it either way.
      So you can do it the RIGHT way by taking the tank out the bottom and removing the pump.
      Or the REDNECK HACKER way of HACKING a hole in the floorand removing the pump.
      I personally recommend the 1st way.
      — Thomas Jefferson
        I'm putting a new pump in my 89 T/A this weekend. Shouldn't be tooo different from a 4th gen.
        I'll let you know how it goes and try to take some pictures.
        88' Trans Am 350 TPI
          Originally posted by WMCC Gary
          ..So you can do it the RIGHT way by taking the tank out the bottom and removing the pump. ..
          thats the way i would do it !!!
            i suppose the right way would be the best its already half tore apart just have to get the panhard rods off then drop the tank. Thanks guys.
