are the front+ rear o2 sensors the same for install?
  • are the front+ rear o2 sensors the same for install?
    while got like 3 different storys from different shops and just want to know from some real f body owners if there interchangeabol. ??? they look the same
    Fronts and rears are almost always different part numbers. They install the same way but are different sensors.
    Wade
      thanks
        If Wade says something ...... Take his word !!! He knows his $hit ..
        **** FEAR THIS ! ***
          i know wade knows his stuff, but ( not to dought you ), someone told me that there only different from the wire lenghts or something. is that true
          thanks
            Oh WADE ....where are you ??????
              same
              In fact most people that have headers use corvette rear sensors
                In fact, I have my stock rear ones in the front now. I killed the fronts and took the rear ones out of my cats cause they had been removed at 14,000miles
                  thakns thought i was crazy when murrays told me different
                    they might have small differances(heater elements) but they work
                      It depends if they are heated front and rear sensors. Not all vehicles have heated front sensors. I know the wire lengths are different depending on location and vehicle, and sometimes plugs as well. My 98 Sonoma didn't have a heated front sensor but my V6 has heated fronts(both ODB2). I bought new ones to replace them(for $200 for all 3!!!) but found a cracked vaccum line was causing my lean issues and not faulty O2 sensors. All rear O2 sensors after the cat are heated types though. I believe there are variations in heated types as well, 3 wire and 4 wire.
                      Wade
                        Except this time
                        Fronts and rears are the same O2 except wire length. Most guys use the vette O2's because they have a stronger heater element that works well with full length headers.
                          this is good because i need to change mine out
                            Except this time
                            Well it's not the same if it has a stronger heater element now is it?!?!?!
                            Wade
                              No...vette is a different set-up than f-bodys. I believe this is due to exhaust design.
