Dyno vid of 502BBC
  • Dyno vid of 502BBC
    Here is a dyno vid of my 502BBC. It is in a 67 camaro, TH-400, 3500 stall converter. This baby is CORN fed.
    http://s241.photobucket.com/albums/f...rrent=dyno.flv
    371 whp and 367ft lbs torque @ 5400 rpm.
    67 Coupe Corn fed 502BBC 4L80E 371WHP/367FT lbs torque
    70 Pontiac Lemans Vert, GTO clone, 427BBC and 7000R4
    Nice!!
      Damn, nice!
        Very Cool!
        - 1988 Camaro IROC-Z
        2000 5.3L | 4L60E | CAI | No EGR | No Cats | 85MM MAF | Tuned by PCM 4 LESS |
        2000 Camaro Dash | 1996 TA Console |
        - 1998 Monte Carlo Z34 (DD)
        3.8L w/ 180xxx miles and going strong!!!!!
            All around nice car
              Thanks for the compliments! This thing is a blast to drive.
                not too bad i guess, what kinda mileage she get on the corn?
                if i have my car next year it'll be corn fed as well
                The LS1 or Go Home Crew
                ASE master certified
                  Nice looking car and it sounds great.
                  I would have expected to see more power than that.
                    Is that at Baker Engineering?
                    2015 Silverado
                      Not sure what mileage will be. I didn't build a BBC for mileage but if I had to guess I am sure it is single digits.
                      Yes it was at Baker engineering.
                        I thought it would put out a little more power also. The dyno guys said it was the converter and tranny sucking up alot of power. TH-400 and 3500 stall.
                          from what ive seen a turbo 400 can eat from 50-100 hp, but its just numbers get some et's but still my car put down more then that and has almost 100 less cubes
                          curious why you went with a 400
                          either way nice man
                          my .02
                            man that thing is sick.
                            where are you finding the corn liquor? there is only 1 place near my house, its 7 miles or so away, but 3.19 a gallon will make it worth while.
                            i am movin my tt truck over to be corn fed this weekend. 24+ psi on pump e85 is gonna be nice, compared to c16.
                              The closest one to my house is about 15 miles. Race gas is alot more expensive. Good luck with the truck.
