What size wheels and tires are you guys running on your First Gen's??
My car came with the steel wheels with GM trim rings and center hub (15 x 8) and it has Hoosier tires (235x60).
If I look at new rims, what is the proper back spacing for the first gen's???
CHEV 383
1968 Camaro SS
383 Stroked Small Block | Barry Grant 750cfm | Edelbrock RPM Heads and Air Gap Intake | MSD Ignition, 6AL box and Blaster 2 coil | Hooker Headers (Thanks CS3Auto) | Stock Muffler
They should be 0 offset with 4.5" BS on an 8" rim, regardless of diameter if you wanted to bump up to 16's, 17's or 18's even.
Wade 2002 Camaro SS T Top Black M6 SLP 345HP 1985 Camaro IROC Z28 T Top Silver 305TPI Auto
Everything stated above is the safe way to go. If you want to push it, I THINK (but not 100% sure) that you can put the same on a 1st and 2nd gen. I am running 17x9.5 with 5.5" BS and 285/40/17 tires in the rear and 17x8 with 4.5" BS and 245/45/17 tires in the front. This is about as far as you can push a 2nd gen with stock rear suspension. That is a lot of tire stuffed under the fenderwell with no rubbing.
'73 Z28 388 Stroker, M22 Rockcrusher 4 speed
WMCC Photographer and owner of Redline Photography You are only young once but you can be immature your whole life!!!
I'm running 206/65/15s on the front on 15x7 Rallye Wheels. I'm about to go back to 14" Cragar S/S, however, because I just found out I've got a broken belt.
-Dave
1968 Camaro convertible. L79/M21.
One-of-none "Hurst Edition"
1975 Ford Green Glow Metallic
Black over-the-door SS stripe
Black top, Ivy Gold Deluxe interior
