Who is running a 5 - 6 speed tranny out there in their first gen?? My old Saginaw 4-speed has seen better days, and I am in the market for an upgrade.
First thing that comes to mind is a Tremec, but they are $2-3k. Anyone running something different, like a newer Camaro trans and like it???
CHEV 383
1968 Camaro SS
383 Stroked Small Block | Barry Grant 750cfm | Edelbrock RPM Heads and Air Gap Intake | MSD Ignition, 6AL box and Blaster 2 coil | Hooker Headers (Thanks CS3Auto) | Stock Muffler
Where I work we are a dealer for kiesler engineering.
We have installed quite a few Tremec 5 speeds in C2 and C3 Corvettes. They are a great piece. Because the first gear is so low you can easily get away with a 3.08 axle ratio and you still have a overdrive so your RPMS on the hwy will be under 2,000. Send me a PM if your interested and I will get you in touch with someone who can get you some pricing.
Some obsitcals you might encounter with a newer 6 speed are hydralic clutch, instead of manual and non cable driven speedo.
If you don't want a lot of work and hassle of upgrading to hydraulic clutch and all that an easy solution would be to just buy a Richmond super street 5 speed. I'm pretty sure they are close to a bolt in. Still can use your original clutch linkage. However, they are just over $3k. Just another thought though.
Thanks for the offer. I have had my eye on Keilser Auto website for some time now. From what I have read, it sounds like I can use a stock Tremec tranny and not really need the modified version for the camaro. Besides, I do not have the center console, so I am flexible on shifter locations. It is more about comfort than console for me.
I will let you know though, if I do choose to go that route.
The 5 speed Tremec's have manual clutches right??
I have seen the RPM sheets for the trannies. My 3:31 gear will be real nice in first with the low gear and very nice with the OD gear. Basically saves me buying a rear end.
CHEV 383
1968 Camaro SS
Later,
Correct the 5 speeds Tremecs come with manual clutch.
We just put a tremec in a 1967 big block Vette with a 3.08 axle. The owner was is so pleased that he can through it in 5 gear at 45 mph and the car putts along at 1,000 rpms.
i have a muncie 4 speed tranny that i would sell for the right price. make me an offer what ever it is worth to you if you want it. i wouldnt want to much for it.
Imagine that big block vette, rolling down the highway at 55 mph in 5th gear, nice and quiet, and downshifting into 3rd and hammering it!!!!! AWESOME!!!
CHEV 383
1968 Camaro SS
