Fuel Lines / Header Gaskets
  • Fuel Lines / Header Gaskets
    Alright, I finally got my car back home with the motor in it and I am now reassembling everything. I have a few questions for the group.
    Fuel Line
    What do you guys use for a fuel line?? My fuel line comes up the passenger side inside the frame and into the engine bay. I have a small fuel filter attached near the front pass suspension. I then use a flexible steel mesh fuel line, loop it into a 180 and back into the mechanical fuel pump. From there, I have it set up good, going to a fuel rail and into my Demon carb. I just need to replace the fuel line from the filter to the pump. I hate working with these mesh lines, but they are simple. anyone use anything else, other than these mesh lines, black tape and hose clamps??
    Header Gaskets
    What do you guys use for gaskets at the cylinder head and going to the muffler side. I've got Hooker headers and Edelbrock Performer aluminum heads. the headers came with gaskets, but don't like them. I have used the brass (soft steel - triangular with 3 hole) ones on the muffler side that seem to work good. On the header side, I have used from 2-piece metal to cheaper kinds. I haven't found the one I like yet. Any recommendations??
    Sure is sweet seeing the old car in my new MAN garage at the new house.
    ORT-2
    CHEV 383
    1968 Camaro SS
    383 Stroked Small Block | Barry Grant 750cfm | Edelbrock RPM Heads and Air Gap Intake | MSD Ignition, 6AL box and Blaster 2 coil | Hooker Headers (Thanks CS3Auto) | Stock Muffler
    4-Speed manual (Saginaw) - 3:31 gears
    I have rubber fuel line all the way from the tank to carb on my 69.
    Was like that when I got it, havnt had time to do anything about it.
    2011 Camaro SS
    1999 Camaro SS #4153
    1986 Monte Carlo SS
    1969 Camaro - 427 Rat
      I would stick with the braided fuel lines, added protection against rocks, heat etc.. As far as gaskets go.. the paper ones work fine for me.. Ive tried the copper ones.. those leaked...
        percy's aluminum gaskets work pretty damn good. I haven't had any problems with mine.
        -Homer Simpson
          Put Copper/Brass gaskets on the '85. Wanted to say they were Hooker Gaskets? No problems with sealing so far.
            Thanks for the input. I've got a new deadline. car show at picnic at work on the 25th. Better get wrenching!!!
            CHEV 383
            1968 Camaro SS
