oil pan leak
  • oil pan leak
    I have a oil pan leak and need to replace the gasket. I was told that you have to jack up one side of the motor to do this. Is this true.
    (1968 camaro RS 327 t350 trans.)
    [SIGPIC][/SIGPIC
    Stainless works headers/cats Roto fab CAI /
    Corsa install and tune Livernois
    TSW Nuburgring 9 &10" x 20 on Invos (315 & 275 )
    JL Audio XD400/4 amp
    Pfadt trailing arms & tie rods sway bars.
    pedders street 1 package
    I don't know about your car but replacing the pan and gasket on m 96 grand marquis I just unbolted one motormount and used the other as a hindge. On the 85 TA the motor has to come out because I was using the same pan and it is a 1 pc pan gasket.
      thanks
      [SIGPIC][/SIGPIC
        you have to get enough space to get the an to drop enough to work. I have unbolted both, and put some blocks in to hold the engine about 4 inches higher
          I had to yank my motor. There was no way to get in there to do the job right, in my opinion. Plus, I didn't want to do the job and have it leak again. Gasket was a lot easier to install with the motor upside down on a stand.
          I would highly recommend a Felpro one piece gasket. They are easy as hell to install, especially if you are looking at doing it on the car. Don't forget to buy a can of gasket cleaner and a can of gasket "glue" to hold that gasket on the engine, while you tighten down the bolts.
          CHEV 383
          1968 Camaro SS
          383 Stroked Small Block | Barry Grant 750cfm | Edelbrock RPM Heads and Air Gap Intake | MSD Ignition, 6AL box and Blaster 2 coil | Hooker Headers (Thanks CS3Auto) | Stock Muffler
          4-Speed manual (Saginaw) - 3:31 gears
