my car has been rewired, the fuel relay was changed out why i dont know but the relay is the matching number to the 92 305 set up, and its under the hood, is the relay for the 94 lt1 diffrent in power per say than the one in the 92, the fuel relay seems to be whats giving me the problem, the relay if you know on the 92 is big and grey while on the 94 is a smaller more compact set up and only a 4 prong set up as the 92 is a 5 prong set up but still only 4 wires.
got it, i can get rid of the crappy set up the guy has i just need to find out where the green wire goes under the dash, the key turns on but no on off to the green, red is on need the green to run the relay then im good on the rest.
