Camaro Ground Effects Memo 7/7/09 - proper installation tips
  • Camaro Ground Effects Memo 7/7/09 - proper installation tips
    The Camaro Action Center and Technical Assistance have received calls related to the GM Accessory Camaro Ground Effects and problems with the front air dam coming loose. After review of each of the calls to the Action center it was determined that the installation instructions were not completely followed. It is important to make sure [...]
    More...
    Automated Birthday Announcement User
    yup. highway speeds make the front lip go
      Sounds like everything they've already said?
        It needs more bolts/rivets/whatever!
          hmmmm so does this mean that it on the recall list now?
            That's what I thought... funny how I haven't seen anything official from GM about the re-design even though I've heard it was implimented shortly before GM went into bankruptcy and the supplier froze(speculation) GM's account. So who even knows. All i know is I've been waiting for a replacement since mid May and the dealer knows no more than anyone else. It's on "back order"... stay tuned
              I guess mini should have checked with us a month ago
              Originally posted by TSTONE View Post
              fyi-
              Date: 06/02/2009 Ref. number: Service / Service Operations / G_0000030351 Subject: Accessory Ground Effects Installation
              GM SERVICE AND PARTS OPERATIONS
              GMSO55
              URGENT - DISTRIBUTE IMMEDIATELY
              Date: June 2, 2009
              Models: 2010 Camaro
              To: Chevrolet Dealers
              Attention: Service & Parts Managers
              The Camaro Action Center and Technical Assistance have received many calls from Chevrolet Service Managers and Technicians related to the GM Accessory Camaro Ground Effects and problems with the front air dam coming loose and dragging on the pavement.
              It is important to make sure that all of the front attachment rivets are installed. There are 16 rivets used for the SS and 4 are installed with the fascia off the vehicle. There are 17 rivets used for the base.
              Do not use petroleum based cleaning products. If a strong cleaner is required use a 3M general purpose cleaners (P/N 08984). Tape will not adhere to a surface with residue left from petroleum based cleaning products.
              Be sure to apply 15lbs of pressure to tape for proper wet out. After the kit has been installed the car shall not be driven for 24 hours. The tape that is used during the installation of the front air dam must sit for 24 hours for complete adhesion.
              Remember there are two different Ground Effect Kits available based on the model.
              Part number 92207441 is only used on the base model Camaro
              Part number 92208008 is only used on the SS model Camaro
              Please make sure your technicians or accessory installers are aware of this information.
              Jack Pantaleo – Camaro Brand Quality Manager
                This is the link from the front page of Camaro5. I'm sure mini will get to it in time, it's usually several hours before it picks it up here...
                http://www.camaro5.com/forums/showthread.php?t=31279
                  Eh? That link is a totally different thread.
                    right, i thought it was better information tho any more current news
