It should have 8 rivets that go across the front of the lip right under the aux grill between the fog lights.
Front GFX Design
I just read your thread and all the ones over on Camaro5 as well seems like a lot of people are having this issue! I hope you get it sorted out Fred!sigpic
I really hope that the mustang guys don't get ahold of this information. They will have a field day.
good idea! I will bring everything.Originally posted by TSTONE View Posti would bring all the broken parts with you on saturday and show Scott - get his opinion
he also might know someone at the supplier that could cut you a break on a replacement piece2000 Trans Am l 1967 Firebird
fyi-
Date: 06/02/2009 Ref. number: Service / Service Operations / G_0000030351 Subject: Accessory Ground Effects InstallationGM SERVICE AND PARTS OPERATIONSGMSO55Date: June 2, 2009URGENT - DISTRIBUTE IMMEDIATELY
Models: 2010 Camaro
To: Chevrolet Dealers
Attention: Service & Parts Managers
The Camaro Action Center and Technical Assistance have received many calls from Chevrolet Service Managers and Technicians related to the GM Accessory Camaro Ground Effects and problems with the front air dam coming loose and dragging on the pavement.
After review of each of the calls to the Action center it was determined that the installation instructions were not completely followed.
It is important to make sure that all of the front attachment rivets are installed. There are 16 rivets used for the SS and 4 are installed with the fascia off the vehicle. There are 17 rivets used for the base.
Do not use petroleum based cleaning products. If a strong cleaner is required use a 3M general purpose cleaners (P/N 08984). Tape will not adhere to a surface with residue left from petroleum based cleaning products.
Be sure to apply 15lbs of pressure to tape for proper wet out. After the kit has been installed the car shall not be driven for 24 hours. The tape that is used during the installation of the front air dam must sit for 24 hours for complete adhesion.
Remember there are two different Ground Effect Kits available based on the model.
Part number 92207441 is only used on the base model Camaro
Part number 92208008 is only used on the SS model Camaro
Please make sure your technicians or accessory installers are aware of this information.
Jack Pantaleo – Camaro Brand Quality Manager
i heard u got a new part coming fred congrats hope it gets fixed soon`The Original
even tho we have seen it with the GFX im calling FAIL on part that there are no new pictures of this GFX up!
Looked great on woodward btw!sigpic
Fail
