PreProduction Camaro Convertible at Oshawa!
The HUB Stadium, Auburn Hills, MI -
\,,/>_<\,,/
- May 11th, 2006
- 10130
- Mark
- 2023 Malibu, 2022 Explorer
- Winston Salem, NC
What are they doing with the rear windows? what are they doing with the rear windows? what are they doing with the rear windows? pics pics pics moar moar moar!!!-Joel
meh... I hope not.Originally posted by TSTONE View Postthey may be part of the top and recess along with it?
That doesnt mean anything. SN95 mustangs had rolldown rear windows on their verts (while coupe's had the fixed windows). I think the newer ones did too but im not absolutely sure.Originally posted by MP81 View PostYeah - most likely - they're obviously not there.
well looky what i found
The convertible also has left rear and right rear power window motors which are controlled by the switches on the driver window switch. When the left rear or right rear switch is used, a serial data message is sent to the BCM requesting rear window opeation. In response, the BCM will send a serial data message to the appropriate rear window motor to move in the direction commanded. There are no rear window switches. The BCM may also globally command all windows to lower in response to a convertible top retract command.
sweet2011 Ford Raptor SuperCrew
Interesting use of technology, but it sounds like something id rather control individually. will have to see. or maybe its just saying there are no back seat switches?Originally posted by TSTONE View Postwell looky what i found
The convertible also has left rear and right rear power window motors which are controlled by the switches on the driver window switch. When the left rear or right rear switch is used, a serial data message is sent to the BCM requesting rear window opeation. In response, the BCM will send a serial data message to the appropriate rear window motor to move in the direction commanded. There are no rear window switches. The BCM may also globally command all windows to lower in response to a convertible top retract command.-Joel
Post Whore-ess
Owns Meissen
- November 13th, 2005
- 9510
- Angie Meissen
- 2002 W68 Firebird, 3800 Series II V6
- Chesterfield, Mi
- Operator/ Receptionist
I thought they were not going to make a Camaro Vert?*Angie*
Sounds like a mixture of two things, hard to tell. 1 part definitely says that there's no back seat switches, but the other part makes it sound like you have a really limited amount of control over when the windows go up and down. But then there's the whole - why would they put window motors in there and not allow us to roll the windows down whenever we want? I'm sure it won't be as complicated as the bulletin makes it sound.Originally posted by JoeliusZ28 View PostInteresting use of technology, but it sounds like something id rather control individually. will have to see. or maybe its just saying there are no back seat switches?
Babe didn't you listen to them at the Cleveland Auto Show? John was asked about the 'vert and he said it will be out a year after the coupe comes out. It sounds like the Camaro convertible is almost a 100% sure thing as long as GM survives that long.Originally posted by FireBirdGirl02 View PostI thought they were not going to make a Camaro Vert?- Brian Meissen
