UMI A arm prob.
  • UMI A arm prob.
    i got these umi lower a arms and i got some front end noise at lower speeds and rolling thu lots..in a earlier post someone said it was the hemi joints..im gona replace em this winter with greaseable ones .. do i need to replace all 4 or is the certain ones that go bad ? front back ?
    I have the same ones and don't have any front end issues. What is a hemi joint?
      the joint where it mounts on the pic.. my car rattles and knocks when rollin thu parkin lots..really annoying and loud
        Heim joints are loud as hell. I have them on my rear sway bar and make a ton of noise. They are mounted vertically so I wouldn't be surprised if that's what's bad on your car. I'd just change them all though. You're going to need an alignment anyways so I'd just get them all done the first time.
        Sent from my SAMSUNG-SGH-I537 using Tapatalk
        2015 Silverado
