So I took the SS over some heavy bumps last night and the front right strut is making noise now. I have lowering springs and I guess Im going to just replace the front struts, cups and mounts. What struts are you guys running ?
Front Struts..... what to use
- Greenville, MI
- Die Maker
There is a company on Amazon that sells the KYB AGX shocks for a great price, just make sure to contact them before hand to make sure they are in stock. I ordered two and it took a week before my refund...called right away to let me know the situation. I said I would wait, but they cancelled the order after 3-4 days. Ordered another set through a different seller and they sent the wrong ones, that took almost a month when before I was refunded.
KYB AGX adjustables with Eibach sportline springs. Feels good to me.Pacesetter LT's, Pacesetter ORY, full MSD ign., 2 step, rear LCA's, SFC's, B&M Ripper, poly motor mounts, Nitto NT05R's, WS6 wheels, KYB AGX adj. suspension, Eibach Sprotline springs, Trickflow elbow w/K&N, All HVAC deleted w/ delete panel, no AIR, No EGR
96 Z28 Camaro M6
2008 Silverado quad cab LTZ
x2, KYB AGX. I have my fronts set to the stiffest setting and my rears set to 5 or 6.- Brian Meissen
Bilstein not too cheap, not too expensive.sigpicMODS: SLP DUAL/DUAL EXHAUST, 160 STAT, MTI LID, SHANER S3 T.B., SMOOTH BELLOWS, DESCREENED MAF, TUNNEL BRACE, UMI SFC & PHB, STRANO SWAY BARS, DRILLED/SLOTTED ROTORS, WHISTLER LIGHTS, BLACK BILLET GRILLE w/69'SS EMBLEM, BLACK SMOOTHED TAIL PANEL w/69'SS EMBLEM, BLACK SS HOOD INSERT, INTIMIDATOR SS WHEELS.
Originally posted by meissen View Postx2, KYB AGX. I have my fronts set to the stiffest setting and my rears set to 5 or 6.
Have to tried different settings?
I put mine at 4 (front and back) and it seems to be pretty darn good. I wish I was a little lower but overall its awesome.1998 Chevrolet Camaro Z28 - 6 Speed
I think I will go with them up front and leave the back alone for the time being. Once I get some cash flow going again I will be looking to change it all up
I figure when I do the fronts Ill look into the energy susp. control arm bushings toosigpic
Go BIG or go HOME!
To be honest I haven't messed around with it too much. I set it to stiffest on all 4 corners when I installed them back in early 09 and just a month ago dialed down the rears to 5. I'll have to tweak the fronts and see how it rides.Originally posted by nascarnate326 View PostHave to tried different settings?
I put mine at 4 (front and back) and it seems to be pretty darn good. I wish I was a little lower but overall its awesome.- Brian Meissen
