Mounting Slicks
  • Mounting Slicks
    Where are you guys getting your slicks mounted? Or are you doing it yourself?
    Anyone putting 3 coats of dish soap on the inside?
    Originally posted by Yoshi94
    take them to harlow tire
      I've always bought them from and had them installed at either McCormick Racing or Harlow Tire.
        Anyone know any place closer?
        To me that is haha.
          just go to any tire shop that mounts and balances tires..
            I thought slicks were better to static balance?
              Any shop static balances. All that is is putting all wheel weights on the inside of the wheel.
              I took mine to Belle tire. They said they had to put them in the truck tire cage, took 80 psi to seat the bead
              2015 Silverado
                correct.. unless you go to some hole in the wall place that has a tire machine from the 80's then im sure they can static balance them
                  Self mounted w/ good ol' dawn dish soap
                    I was thinking of applying 3 coats of dish soap over 3 days then mounting them.
                    But okay, I didn't know a regular tire shop could balance static.
                      bubble balance slicks
                        They do that at tire shops?
                        I don't do enough wheels to justify buying a bubble balance.
                          Static and bubble balance should be the same.
                          Do not let them dynamically balance them - they'll shake like a mother.
                          2000 Formula
                          fixed slow junk
                            Do you guys just run the stick on weights?
