Will these fit my camaro ?
  • Will these fit my camaro ?
    My friend has a stock 1993 camaro will these fit ? they are on ebay
    Wheel Specifications:
    Wheel Sizes: 17x8” (Fronts) and 17x9" (Rears)
    Wheel Construction: One piece cast aluminum alloy
    Wheel Finish: Chrome (Triple chrome plating - Copper, nickel and chrome)
    Lug Pattern: 5x4.75” (same as 5x120.65mm)
    Offset and Backspacing: 17x8” wheels: 0mm offset (4.50” backspacing) 1 1/2” Lip Size 17x9" wheels: 0mm offset (5.00" backspacing) 2 1/2" Lip Size
    Center Bore: 2.88” (73mm)
    Tire Size (s) / Dimensions:
    Fronts: 235/45ZR17 Rears: 275/40ZR17
    Overall Diameter: 25.4" Overall Diameter: 25.7"
    Section Width: 9.3” on a 17x8” rim Section Width: 10.7” on a 17x9” rim
    Load Index: 94W (Max Load 1477 Lbs) Load Index: 98W (Max Load 1653 Lbs)
    Traction: AA Traction: AA
    Temperature: A Temperature: A
    Speed: W (168 mph) Speed: W (168 mph)
    UTQG: 340 UTQG: 340
    Sidewall Height: 4.16" Sidewall Height: 4.33"
