I have been wanting sub frame connectors for my car and been wondering if the 3 points are worth the extra $150+ and extra weight? I do know that if i want a aftermarket torque arm i need a 3 point but i dont plan on buying one of those anytime soon
2 point vs 3 point sfc
95 Trans Am:
Kooks longtubes/ory with GMMG catback, Edelbrock throttle body, MSD Ignition, MSD Coil, LPE Cold air intake, Ford SVO 24lb fuel injectors, Ported and polished intake manifold, Racetronix fuel pump kit w/ hardwire kit, Aeromotive adjustable fuel regulator, Tuned.290rwhp/320tq...
2004 Electric Blue SRT-4:Forged JE pistons,
6061 billet Crower rods, polished, balanced and knife edged crank, ARP studs, directfit fmic, Mopar stage 3 turbo kit on 25lbs of boost, downpipe, dsp, mopar short throw, mbc, ported manifolds, act hdss clutch, walbro 255 pump, 750cc injectors, tuned, E85 conversion coming soon. SOLD.
2005 GTO: Sport Appearance Package, Corsa Sport Catback. -
Depends on what direction you are going with the car. I would say the 2-point SFCs are good for general use and straight line stuff, whereas the 3-point SFCs are better for auto-x/road racing and big-hp straight line cars.
I have 2 point. 3 point just seemed overkill for me and I got a good deal on the ones I have.sigpic
I agree with Spencer. If you're buying SFCs to stiffen the chassis, to me 3pt is the only way to go.
IMG_1438.JPGLast edited by meissen; June 18th, 2012, 06:46 PM.- Brian Meissen
Mine does the same thing with 2 point and 3 point is not required for aftermarket torque arm. I use a spohn chassis mount torque arm.Originally posted by meissen View PostI agree with Spencer. If you're buying SFCs to stiffen the chassis, to me 3pt is the only way to go.
[ATTACH=CONFIG]42234[/ATTACH]sigpic
Installing 2 point connectors will make the body 20%(?total guess?) stiffer but installing 3 pt connector is going to make it 22%(total guess) stiffer. What I am saying it 2 pt connectors will make a noticable improvment but comparing 2 pt vs 3 pt the difference isn't as drastic.
....and the problem that is? Btw, fixed for youOriginally posted by ryanwarby01 View PostI have 2 point. 3 point just seemed ovrkill for me and I got a good deal on the ones I have.
3pt, ftw....Just need to save enough to get some
http://www.midwestchassis.com/subframe-connectors.htmlOriginally posted by c0ncEpT View PostA true 2 point SFC like the midwest piece will do more for you than those 3 points that mount to the LCA bracket and that sheet metal tunnel brace bracket.....
Midwest Chassis builds some awesome stuffsigpic
These are better then umi 3 points?Originally posted by ryanwarby01 View Post
95 Trans Am:
Yes -they tie the chassis together. The only thing better is thru the floors like the ones listed here: http://www.ktsracecars.com/cages.htm
That being said - I have UMI's bolt in 2 points. Some MWC connectors will find their way on my car when I'm able to weld again.2000 Formula
fixed slow junk
Il probably go with these since they are the best but i need to know a good place to have them installed.Originally posted by Nocooler View PostYes -they tie the chassis together. The only thing better is thru the floors like the ones listed here: http://www.ktsracecars.com/cages.htm
95 Trans Am:
