youre gonna want something a little wider. when looking at tire sizes like 245 55 16 the 245 is the width of the tread in millimeters ( i think) the next number is called tha aspect ratio and tells you the sidewall height. it is a percentage of the tread width so it means that the tread width of the example is 55% of 255. the last number is the diameter of the wheel that the tire will fit.
I know someone who has a 225 tire on a 8 inch polished Z28 wheel
2slow.....You will want a 275 series tire on that rim to look proper.
hey its a 235 thank you very much and 8" is a little different than 9.5. its not like i chose to put those stupid tires on there, and im too poor to buy new ones right now
go 275/40/18 all they way around that will look the best. although expensive they will look the best. i THINK the cheapest i can get them for is $160 a piece not mounted which isn't bad. you could go 255/45/18 they are alot cheaper but look like crap
1995 TA Sold. i sure do miss it though.
1998 Trans Am aka Winter beater
