Relocation brackets or no brackets?
    Originally posted by ThreeHonks View Post
    brackets are a great mod
    not if you have ladder bars. lol
    97 TA AI 355
    2012 Jeep Patriot
      im sure you can still use them. you just have to have everything else set up properly. the ladder bars are not at fault here or the bracket, it was the builder.
        I would think the lca mounted lower on the relocation brackets should still work fine as long as you pre set the pinion angle before welding the attachments.
          When using a ta you don't have to worry about them because they arnt you main spot to locate the rear end, so when you add them with the lcas relos it changes the whole position of the lcas(which is what I am supposed to be using for my torque arm setup) so it throws the whole geometry off. If you can find me a ladder bar setup with lca relos then I will admit I am wrong lol.
          97 TA AI 355
          2012 Jeep Patriot
            it just needs to be setup with the lower control arms on in the first place. if you setup your pinon angle and ladder bars and then put on brackets, that would be a big no-no
              you could always upload a picture of your LCA for us too.
              2002 Z28 Camaro A4
                Well thanks everyone, people on LS1tech are back and forth on if they are worth it. Im picking some bolt ons for 60 shipped.
                2002 Z28 Camaro A4
                  front mount on a ladder bar is adjustable. does the same thing as relo brackets or moving the front of the TA
                    its the only susp mod i have and it completely got rid of wheel hop.
                    2000 Z28 - Cammed/Stalled/Intake - Collision With a Tree Mod - Totaled
                    2005 Grand Prix GXP - Sold
                    2000 SS - Sold
                    2011 Ford Taurus limited - Time for a practical car for a bit
                      lol, i meant on the car to show us the angle
                        oh
                        I don't have them on yet. Just bought them from Kyle (kyleozzie).
                        Brackets should be in sometime next week.
                        2002 Z28 Camaro A4
