what size tire?
  • what size tire?
    what size tires should i run on the rims im getting. there summit fast fives. ( look just like weld pro stars) on my 94 camaro z28
    15x8 in the rear ( want a fatty tire)
    15x4 in the front ( want streetability)
    looking for the old school look. im also getting air shocks for the rear to help raise it up a little.
    HISTORY OF CARS PAST AND PRESANT (none of them were wrecked)
    1989 S10 standard with 350 carb'd, th350, shift kit, shorties, 600cfm, hooker TD's, 3.23 non posi, B&M shifter(sold)
    1991 firebird with t-tops and 3.1L, 700r4, 3.23 non posi, flowmaster cat back, 15ibs injectors, (sold)
    1991 formula with t-tops, WS6, 5.0TPI, WC T5. 3.42 posi. magnaflow cat back, 52mm TB, and hurst billet (sold)
    1994 camaro z28 with t-tops, 5.7LT1, T56, 3.42 posi. CAI, elbow, Airfoil, SFC, STB, pro 5.0, flowmaster cat back. (sold)
    2000 Trans am with t-tops, 5.7LS1, T56, 3.42posi, LT'S, ORY, magnaflow, lid, lingenfelter intake, 3pt SFC, STB, LCA, (current)
    cant ya fit like 275-295's on the rear? that would be plenty for ya.
      idk thats why i was asking.
      im not good with tire sizes and stuff
        275 is about the biggest you can go on that rim and that should be plenty if you buy the right tire for it.
          If you want streetability I would suggest buying wider wheels in front. With that small of the wheel your tires wil be very skinny and it will grab the groves in the road. I would get at least 15x5". Shoot I think the aveo's have wheels that are 5.5 wide.
            275/50/15 in the back...
            the fronts are you looking to keep it skinny and fattys for tires or what??? if wanting the skinny fatty look go with a 26/6/15 if you wanna go more street looking u need something wider then a 4 in the front for a rim width
              well I sure hope these are track only tires, I know they aren't suited for daily driving on these shitty ass roads.
                its a daily driver. i want the old school fatty look but keeping streetability.
                the only rim sizes are 15x4, 15x7, 15x8, or 15x10
                so it looks like 275/50/15 for the back. the front i want the best streetable tire size. or do i need to get a wider rim?
                  You just bought wheels and tires? If your using this setup for a DD and to drive on then yes you have to ditch the 15x4 front wheel size. Might as well just go 15x8 all around with a smaller tire up front.
                    i got the rims for my mom. so i wont be able to run the 15x4 rims?
                    can i run 15x10 in the rear. if so what tire can i run on that size rim? thanks
                      I am sure you "could" run the 15x10 wheel and throw some 315's on there would be nice, but that may require some BFH mod time...
                        those are not good rims for daily driving they will bend on the potholes around here. Thats why they are track wheels.
                          im in north carolina in a marine corp base. not alot of pot holes here. and really not that many where i used to live.
                          so front rim/tire should i go with the 4, 7, or 8 in rim and what tire to match it?
                          thanks
                            if you get on a expressway at 70 and go into a curve with a 4" rim it gets sketchy lol just a warning.
                              thanks
                              Get 15x7s in the front with 215 or 225 if you wanted to stay on the skinny side
