If you see this camaro, don't mess with it unless you like to be spanked!
  • If you see this camaro, don't mess with it unless you like to be spanked!
    I had the pleasure to spend a few days with Rick Hollenback, from Synergy Motorts in Fremont Ca, Rick is a seriously talented performance guy who is just about as anal as I am. Rick has been certified in all our Pedders platforms except Camaro. Guess what we did for 2 days!!
    Rick and I set this one up significantly more aggressive than I normally do. Why? Check out the wheels!. Custom Forgelines with 305 RE11 Bridgestones on all 4 wheels, custom built to Pedders specs. They are the same configuration as the Pedders Camaro. I will let the owner post up the specs if he wants. But all I can say if you see this Camaro going thru the twisties, do not even try it unless you are a sadistic person who likes to get spanked!
    thanks
    mike
    DMS
    Not a fan of the wheels at all, but to each their own.
      I dig it, and think those are some of the best wheels I have seen on a 5th
        I'm sure that Camaro handles like crazy, but I hate the wheels, too. (I'm not a fan of black wheels) But, to each, their own, I guess.
        RIP Doug,You will always be remembered
        3/3/53 ~ 12/22/10
        1985 Camaro IROC-Z
        1974 Camaro Type LT / Z28
        2002 Trail Blazer LTZ
        1996 Camaro SS (Sold )
        www.wmcamaro.org
          I bet that thing handles like its on rails. I think it looks sweet!
          1999 Trans Am NBM M6 || Stock short block || Livernois stage 2 LS6 heads || Speed Inc. SI5 cam 231/237 .589/.595 112 lsa || LS6 intake || P&P throttle body || F.A.S.T. 36 lb.injectors || Ls6 oil pump || New timing chain, gears and cam bearings || GM performance lifters || Comp pushrods || Comp 918 valvesprings || SLP lid || SLP underdrive pulley || Jethot long tube headers || ORY || Borla exhaust || Hurst short throw shifter || LS7 clutch || BMR lowering springs || Tubular control arms || BMR panhard bar || BMR torque arm || 4.10 gear || 10 bolt rear with welded axle tubes and a TA Performance girdle || Drilled and slotted rotors || SLP subframe connectors || BMR driveshaft loop || SLP Firehawk hood || SLP Firehawk Wheels || Nitto Drags || EVI Dyno Tune 436RWHP/ 413RWTQ
            Sooo you said the owner may like to post up the specs? Is this said owner a member here???
              Id love to see a comparison like MT does on a bone stock LT1 car, bone stock LS1 car, and bone stock LS3 camaro.
                I like the wheels!
                  Looking good.
                    looks good. and theres alot of handling mods done was any work done to the engine?
                    See im the oposite i love the way it looks but it seems like the wheels are a little small for the car but looks good.
                    94 V6 A4>>>>LT1 M6>>>>>>383 M6 13.1 @ 109 2.2 60' Sold/Stripped
                    94 Z28 383 LT1 A4 SNAPPED CRANK
                    1992 Camaro RS 305 700r4 Convert.
                    1986 Dodge Ramcharger 318 Dually Rear, Camo paint. Scrapped
                    1993 s10 4x4 5spd 4.3 on 31s awaiting a lift. [COLOR=rgb(0,0,0)]traded for...[/COLOR]
                    1998 Jeep Grand Cherokee 4.0 I6 getting 3in lift and 31s within a week or two
                    "Life is full of decisions, You make them and don't look back"
                      Probably looks funny because the wheels aren't staggered. As for the tires, what's the wear rating on them? Look pretty sticky.
                      Used to own a Firebird.
                        Forgeline makes a variety of the wheels that are customized for the Camaro and maximum performance. The Forgeline wheel gives us abilities that no other wheel out there does
                        mike
                        dms
                          Nice Car. I think it would look better with bigger wheels.
                          2002 z28 Camaro Red M6.
                          -Magnaflow Catback, 4.10's, Mosher Axels, TA Cover
                          SOLD:
                          1999 Camaro 3.8 Y87-White
                            It's good looking,I like the wheels just not on a blue car. Maybe if the windows were tinted dark,but that's just me
                            The first Gen started it all!!!
                            67 CAMARO RS AND A SEXY WIFE
                              wheels are too small
