i would go with the 18x9.5's for the front, anywhere from a 38mm to 56mm offset should fit fine, just to keep it matched up with the front, i would go with the 56mm offset in the front as well, that and throw some (edit, i meant 275) 275-35R18 tires on there and you will be set!
