Tire "Stretching"
  • Tire "Stretching"
    Wow, so apparently the import guys really are that much different than us. Whenever I have seen cars that have tires a bit to small for the rim, I thought that they were just being cheap. But, I stumbled across this thread, where they actually think that it looks good, and see how far they can go with it!!! A few of the guys can fit their finger in between the tire and the lip of the rim. I don't even understand how that would work, lol
    Anyway, heres a few pics.
    The stuff people do boggles my mind sometimes.
    WTF!!!!!!!!
    burn rubber!
      Idiots! I really don't see the point, but to each their own....
      Originally Posted by 1BADAIR
        Pretty sure that is super dangerous...
          its more of a euro thing..
            Retards.
              to much
                What the hell?
                  Almost as dumb as me putting 315's on my firehawk wheels lol
                  1999 Trans Am NBM M6 || Stock short block || Livernois stage 2 LS6 heads || Speed Inc. SI5 cam 231/237 .589/.595 112 lsa || LS6 intake || P&P throttle body || F.A.S.T. 36 lb.injectors || Ls6 oil pump || New timing chain, gears and cam bearings || GM performance lifters || Comp pushrods || Comp 918 valvesprings || SLP lid || SLP underdrive pulley || Jethot long tube headers || ORY || Borla exhaust || Hurst short throw shifter || LS7 clutch || BMR lowering springs || Tubular control arms || BMR panhard bar || BMR torque arm || 4.10 gear || 10 bolt rear with welded axle tubes and a TA Performance girdle || Drilled and slotted rotors || SLP subframe connectors || BMR driveshaft loop || SLP Firehawk hood || SLP Firehawk Wheels || Nitto Drags || EVI Dyno Tune 436RWHP/ 413RWTQ
                    no, i dont think so lol
                    I think putting too small is worse
                    and looks less safe
                    1996 Base Model
                    +2 cylinder mod
                      So I talked to my import buddy about this and he says quote "the guys in japan wanted to have matching rims but it was hard for them to drift with a 10" wide tire so this was there solution...he said he runs a tire that is over-sized for his civic because he wants more grip for the track..." so his sidewalls are flexed inward...I don't think I would do it if someone paid me to try...
                      burn rubber!
                        I seen a Civic like that last week. I thought they were crazy!
                          people do the dumbest things. Tires are expensive enough, why not get ones that acctually fit and wont blow out on you. Should be illegal, they could have a tire blow out at any point and risk the lives of those around them
                          -Derek-
                            beats the hell outta me!?!
                              my fronts are nowhere near that bad but i need a bigger tire then a 255 for my vette rims, its bothers me that they dont fit properly and but its nothing like this.
