Coil Spring Question
  • Coil Spring Question
    Will Stock WS6 Srpings go on my Camaro without any modifcations?
    What about the springs the go around the struts
    I am pretty sure they will
    just dont want to buy them and them not
    thanks
    1996 Base Model
    +2 cylinder mod
    They will fit with no modding.
      Are ws6 ones supposed to look kinda streched at the base, where they sit on the axle?
      1996 Base Model
      +2 cylinder mod
        FZM 22077196
        can anyone tell me what that part number means
        1996 Base Model
        +2 cylinder mod
          The larger spacing between coils near the bottom of the spring indicates a progressive or dual rate spring (most rears are this way).
          If your looking for specific spring rates heres a link with some good info.
          http://www.angelfire.com/my/fastcar/suspension.html
          Also keep in mind that after Jan `00 all WS6's used the same spring as the regular Trans Am's. The 1LE Springs were discontinued after that.
          EDIT; Sorry forgot the link
          Craig
          Semi Retired Street Racer
          GONE BUT NOT FORGOTEN
          NBM `98 Formula M6 HdTp
          1 of 1 Build Date 3/12/98
          - Smokey Yunick
            will putting the ws6 fronts on my car change my alignment?
            1996 Base Model
            +2 cylinder mod
              The Springs themselves won't change the alignment, but the dissassembly of the ball joint will require the car to be realigned.
              Craig
              - Smokey Yunick
                yeah, thats what i was thinking.
                i guess if i do it ill have to take up to my dads work or somthing
                1996 Base Model
                +2 cylinder mod
