Sorry for the pic quality, will get some better ones in the daylight. It was starting to get dark but I'm excited! 315 Nitto drags in the back, 275 Nitto 555 up front. They look a million times better in person, now I basically have a Firehawk replica. Always wanted one but couldnt afford one when they came out.
1999 Trans Am NBM M6 || Stock short block || Livernois stage 2 LS6 heads || Speed Inc. SI5 cam 231/237 .589/.595 112 lsa || LS6 intake || P&P throttle body || F.A.S.T. 36 lb.injectors || Ls6 oil pump || New timing chain, gears and cam bearings || GM performance lifters || Comp pushrods || Comp 918 valvesprings || SLP lid || SLP underdrive pulley || Jethot long tube headers || ORY || Borla exhaust || Hurst short throw shifter || LS7 clutch || BMR lowering springs || Tubular control arms || BMR panhard bar || BMR torque arm || 4.10 gear || 10 bolt rear with welded axle tubes and a TA Performance girdle || Drilled and slotted rotors || SLP subframe connectors || BMR driveshaft loop || SLP Firehawk hood || SLP Firehawk Wheels || Nitto Drags || EVI Dyno Tune 436RWHP/ 413RWTQ
Not sure whats up with the wheel weights lol. I was to excited to notice but damn it looks like theres about 20 on that one wheel! Thanks for the comments guys! Hope to make it down to woodward tomorrow!
Rims look great, but putting 315s on a 9" wide rim is a huge No No.
I know but really am not worried about it. They look good and grip so thats all that matters to me. I only drive 2 miles to work and everywhere else we take the TBSS so no worries...
Meh, says Ls1tech, but it is done ALL THE TIME. It would be one thing if it was a goodyear GS-D3 or somthing for a tire, but the Nitto DR run really small. I'm really suprised to see how many people that do it. The tire is too wide with not enough sidewall to make up for the difference Nate.
This is what looks like a BFG DR, so the difference would be even less.
