Size on tire width.
  • Size on tire width.
    I have a set of wheels im trying to sell. I was curious if they would fit on an fbody specificly a 4th gen. I know the fronts will but i am unsure on the rears, im hoping someone can help me. The rim is 20x10.5 and they have a 305/25/20 tire on them. The backspacing is 65. If the will not fit could anyone tell me what size spacer i would need to make them fit. Im not going to post them in the forsale section or anything because i hate when newbs come to my forums for that reason. Im just looking for information. Thanks
    i cant tell you if they will fit because i know nothing about backspacing. haha. but lots of people run 315 tires with just a little hammering to the wheel well. someone should know tho
      Give OE Wheels a call - they should know the backspacing to be sure.
      1-866-273-3651
      The 305 wheel should fit no problems but it's the backspacing that will really make the determination on fitment. I vaguely remember ~60 backspacing being the right number but it's been a few years since I bought my rims.
      Edit: Looks like I was wrong, here's two good posts:
      http://www.camaroz28.com/forums/show...4&postcount=15
      http://www.camaroz28.com/forums/show...87&postcount=9
        Probably not...4th gens have a 54 mm backspacing stock...so I think you'd need a 10 mm spacer and probably the bfh mod...but it's close...
        And you'll want to check the length of your lugs to see if a spacer and be put on and still have sufficient thread engagement.
          Is BFH mod = Big F'g Hammer?
          2008 Charger R/T - Stone White - DD.
          2001 Pewter WS6 M6 - Borla, some induction mods, a little bit of this and a pinch of that, 2 Hookers, and a pipe.....
          Updated Pix 9/2009
          http://www.cardomain.com/ride/2151616
            nailed it
